Derbi Terra levers
coyik
Derbi Terra levers
Ongelezen bericht door coyik »
Does any one know where i can get sone aftermarket adjustable levers for my 2016 Derbi Terra, i have some GYZF levers that i cut to size but as a result the brake light stays on due to the design of the piston and light activator. Any help appreciated.
gpr050
Vervoersmiddel: Derbi gpr50
Re: Derbi Terra levers
Sorry coyik, I don’t have the information what type of levers will fit the Terra. What I like to bring to your attention is, to be really careful using aftermarket or universal levers. Make sure the lever does not touch/press against the rod, or piston when not used. If so, and this has to be only a very small amount, pressure stays in the brake system and will not be released. This results in continuous breaking, hot brakes and even blocking of the wheel. You don’t want to experience this while riding with 60 m/hr
Vervoersmiddel: Aprilia RX
Zero DS
I do not know any specific levers, but if you look at your OEM supplier, they have an original spare part number. If you google that you can see what other bikes use the same. If there is an aftermarket for any if these bikes you can find the levers.
